1979 ford truck wiper motor
Old 07-30-2013, 08:00 PM
okie#1's Avatar
okie#1
okie#1 is offline
I have 79 truck finishing up a complete frame off, installed a new wire harness(factory) and testing all equipment in dash. all works but the wiper motor. new motor and switch. replaced twice. the washer pump works but the wiper motor will not turn.
Old 07-30-2013, 08:12 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Welcome to FTE. Do you have standard or delay wipers?
Old 07-30-2013, 08:42 PM
okie#1's Avatar
okie#1
okie#1 is offline
delay wipers
Old 07-30-2013, 08:47 PM
mikeo0o0o0's Avatar
mikeo0o0o0
First, make sure the orange w/ white trace wire has 12v and make sure the switch itself is grounded. The original switch grounds through the metal dash. Replacement switches have a short ground pigtail because the same switch is also used on later models that had plastic dashes.
Old 07-30-2013, 11:47 PM
VocaTexas's Avatar
VocaTexas
VocaTexas is offline
Did you put the ground strap back on the wiper motor? There should be a copper strip under one of the mounting screws that grounds to the body. If it ain't there, wiper motor won't work.
Old 07-31-2013, 03:39 AM
okie#1's Avatar
okie#1
okie#1 is offline
groud strap is in place, I have not tried to put a separate ground yet.
Old 08-01-2013, 06:23 PM
okie#1's Avatar
okie#1
okie#1 is offline
wiper motor issues 79 f 250
ok new 2 speed motor, new switch, with delay?? but it does not have a box??both motor and switch are grouded and 12 volts are coming to the switch. when I push in the switch the washer works!! could it be the missing box between the switch and motor???
Old 08-01-2013, 06:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yes, you're missing the governor box.
Old 08-01-2013, 06:36 PM
okie#1's Avatar
okie#1
okie#1 is offline
where can I get one ???
Old 08-01-2013, 06:39 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Craigs List, E-bay, salvage yard.
As far as I know, no dealer has any left in stock.
I see them on e-bay quite often
Old 08-01-2013, 06:45 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If you don't have to have delay wipers, all you need to do is get the standard non-delay switch and plug it into the harness.
Old 08-01-2013, 06:48 PM
okie#1's Avatar
okie#1
okie#1 is offline
also I pluged into the original switch that does not have delay and the wiper motor still would not move
Old 08-01-2013, 06:56 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Check the orange w/ white trace wire for power. The fact that the washer pump works isn't a valid test. The windshield washer receives power from a separate source (white wire w/ black trace).
Old 08-01-2013, 07:05 PM
okie#1's Avatar
okie#1
okie#1 is offline
no blown fuses, where is the supply for it ???
Old 08-01-2013, 07:19 PM
mikeo0o0o0's Avatar
mikeo0o0o0
According to the factory wiring diagrams, the windshield wipers receive their power through the ignition switch and that circuit is protected by a fusible link, not a fuse.
If there's no power at the wiper motor, check the fusible links at the starter solenoid. These are easy to check. The wires will have little flags on the that says FUSIBLE LINK then the size, something like 16 ga. take the wire and "tug" on it. If it feels soft or stretches then its bad and needs to be replaced.
Also, you can go here for copies of the FACTORY wiring diagrams. On the '79 copy, the windshield wiper circuit is on page 9.
1973-1979 Ford Truck Wiring Diagrams & Schematics - FORDification.net
Quick Reply: 1979 ford truck wiper motor
