Help - Alternator Wiring Harness
So I was changing the belt on my truck and discovered that the wiring harness going to the alternator was more or less melted. I haven't been able to find one to buy anywhere, but I found one for a mustang (same motor) that looked similar to build from. So far I'm not having any luck getting it right.
Does anyone know where I can buy a harness? Or can someone send me a photo of their harness or know where I can find a wiring digram that I can use to build one? My old one is so shot I can't tell what was running where.
The truck is a 1970 F100 with a 360.
Master Diagram
Here's a link to a 'Master Diagram' for your truck. Hope it helps.
http://www.fordification.com/tech/wi...-70_master.jpg
Maybe it is time to do a 3G swap and update 40 year old technology? Might be cheaper and easier?
https://www.ford-trucks.com/forums/1...lternator.html
Mustang alternator harnesses have been reproduced, but they don't always work on F100/350's.
1970/72 F100/350: There are two different alternator harnesses:
DOTZ-14305-S .. Use with oil/amp GAUGES / DOTZ-14305-X .. Use with oil/amp WARNING LIGHTS.
Since most parts are typed into websites with the letter O and that's how we pronounced it, that's how I list the part number. But I always run it both ways.
D0TZ-14305-S = NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
Can you clarify a little more how the wiring side of things would work. I only know enough about electrical to get myself in trouble.
you don't need to buy a harness.
here's all the diagrams you'll need, whether you go 1G or 3G:
Fuel Injection Technical Library » Alternator Files
for what its worth, the 3G is a great swap, but if you're not electrically-minded, it may be best to just rewire what you've got.
kkubina
01-03-2016 04:17 PM
jaybro28
01-03-2016 03:35 PM
Kim Rowden
10-24-2015 04:03 PM
shanes66charger
10-30-2010 10:52 PM
FourSixBullitt
10-05-2010 07:08 PM
