05 3v f250 No start.
Old 07-28-2013, 04:49 PM
94z28guy's Avatar
94z28guy
94z28guy is offline
Hey guys I work on a fleet of fords an have got stumped, so im here for some expert advice. The truck as stated in title is a 05 f250 with a 5.4 3v and the 5r110 tranny. Its throwing p0706 and p0707 codes for the range sensor, so we ordered a TRS and just plugged it into the harness with no change. It will bump over in gear if the switch is turned fast enough, It does not illuminate reverse lights while in reverse, and starts 25% of the time. So yes the problem is intermittant. We are probably going to go ahead and install the range sensor although it seems it isnt the problem. My question on that is how the heck do you remove the roll pin on the lip for the trans pan?
TIA
Old 07-30-2013, 07:16 PM
94z28guy's Avatar
94z28guy
94z28guy is offline
Solved, Pass side harness comming from the ecu had got against the exhaust manifold, Soldiered the wires and fixed.
Old 07-30-2013, 07:20 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Glad you fixed it . Glad you posted your fix ! I hate dead threads .
Devin Russell
1999 to 2016 Super Duty
11-03-2015 01:26 AM
Marty's 97 F-150
2004 - 2008 F150
03-30-2012 11:24 AM
86mustang
01-14-2007 04:33 PM
superv10
11-16-2004 05:56 AM
Quick Reply: 05 3v f250 No start.
