06 F150 Transmission Using Oil - No Leak
My 06 F150 - 4x4 - 5.4 - transmission required 3/4 qt.(litre) approx. 600 mi.(1000km.) ago and now is down another approx. 3/4 qt. (lire). Can't see any sign of a leak.
Is there any way the oil can get sucked into the engine or ? via a vent/vaccume line or ?
Will also have to check the transfer case.
What are your thoughts ?
Thanks
Thanks
Canadian Hunter,
Had my '04 in the shop a couple weeks ago for a routine service at 102K. Trans was 2 qts low, T-case was 2 qts hi. They had to pull the drive shaft to get the t-case out and replace a seal. Grand total was $527 USD. All is well now. By the way, once they pulled the drive shaft, the rear seal started leaking so they refreshed that as well. Good luck!
crucialprospect
03-04-2017 08:05 AM
run6.0run
06-24-2012 08:14 PM
soron3842
03-21-2011 08:07 AM
