OEM Paddle Mirrors
OEM Paddle Mirrors
Where is the best place to get them new if you still can? I grazed a bush to avoid an oncoming car that was driving right in the middle of the road and busted my passenger side mirror. It shakes like no other and will not turn at all without the plastic buckling. it is completely useless. Can I stil get OEM ones new? Where would be the cheapest place to get them new? How do they compare to reproduction ones? Thanks again guys.
They're Keystone Styling units, come in Keystone boxes, etc..
The issue is, they don't handle vibrations well, and turn straight down towards the ground.
Looks wise, etc...Perfect shape, form, etc.
Just a bad "Inner" portion; However, if you have the OEM ones, you could do the ol' "Gut an swap" and have new mirrors, that won't turn straight down.
I have a set of those POS's on my truck. Bought them from Partsgeek, and as usual, had excellent service.
Also, a word to the wise, the bolts that holds the mirror on; There's 3:
-2 Torx style units on the outside, and 1 bolt on the inside, that stabilizes the unit.
Those 2 on the outside are extremely soft metal, think "Pot metal". If you aren't careful, you'll strip them out and be screwed.
I actually had to go to the next size up, and use a hammer to press the ''fins'' of the Torx head bit into the bolt head; And yes, it's THAT soft.
The replacement mirror comes with new bolts, in a Phillips 4 way version; But they're just as F$#*&#in soft of metal.
So take extreme care.
I'm using OEM mirrors. I suggest looking for a good used set. I have not see a quality set of reproduction sport mirrors for our trucks. They all seem to fade quickly in the sun. I had a chrome pair that the actual mirror part would vibrate badly making them useless on the highway. My friends black set whistle. Its just junk. I'd rather have a set that cost even as much as $100 that was good quality. There seems to just be more and more el cheapo reproduction parts. I just don't get it.
EPDP99
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-13-2006 11:00 AM
