Fuel Bowl Rebuild questions
Alright, I have been looking all over for the fuel bowl rebuild info and have most of it figured out.I am getting ready to order the o-ring kit from dieselorings and the hoses as well. Anything else I will need for this? Also, when I drain the fuel bowl and refill after I am done, is there any priming of the fuel system needed or is it pretty straight forward?
yeah, leaking fuel enough to have it in the valley of death and leaving drops overnight, not to mention the diesel smell coming into the cab. I don't mind it so much, but the wife and little girlie, not so much.
If anyone wants to come walk me through this, there will be unlimited Coors on ice. Nate? Travis?
Check the inside bottom of your fuel bowl . Mine was rotted out and caused the diesel in the valley . Fixed it with job weld . Worked fine until I deleted my fuel bowl. The rebuild was simple . I did however bought new factory fuel lines to go between the bowl and the pump .
on
1 Post
I need to get this dang truck tight!!
on
1 Post
I built my own e-fuel system for less than $350. Travis is right, you don't really need it until you do injectors, but if you have the bowl and everything already out, it would be a good time to do it. I say that because I just got tired of fuel leaks. I rebuilt my bowl, installed a new pump, plugged the fuel restriction sensor and still had leaks.
Easy to remove, I hate putting them back in. That's why I went to e fuel when my pump started leaking. Mine was done for around 350, thanks to a couple of nice fellas on this site!
I feel bad ya already bought stuff to re-do the bowl. I told myself id either do e-fuel when i upgraded injectors or when the bowl was leaking terribly.
lol
Either way tho here's some helpful links!
TJ's writeup has a good bit of parts listed: https://www.ford-trucks.com/forums/1...-compelte.html
And King's is helpful as well: https://www.ford-trucks.com/forums/1...gs-e-fuel.html
You can modify the builds to your liking. Basically you just need to have a pump with two filters and some lines in the valley with a regulator.
Kinda putting that simply, but just to get the idea across.
lol
lol
lol
Heck for $500, I'd almost pay someone to do the whole thing. Looking at all of those parts and getting the right stuff seems overwhelming, but I like doing it myself, so I'll figure it out.
