4R100 Locks up at idle!
Hi all,
We have recently had an intermittent problem where, when I put the truck in drive after backing out of a parking spot, the truck lurches forward and then stalls. Then, when I put it in neutral and fire it back up and put it back in drive, it charges forward, and I'm hardly able to hold it with the brakes. But then, when I put it into park and turn it off and turn it back on, it's fine. It seems as though the torque converter is locking up when I put it in drive after backing up. The truck went to the dealer for diagnostic of an unrelated issue, and they said that it happened to them as well. They believe the trans is on it's way out, but it didn't throw any codes, although they remarked that they fluid smelled burnt, even thought it was changed about 7k miles ago. Has anyone else ever heard of this? It's a 2003 F250 with a 7.3 and a 4R100, 185k miles. Thanks!
I would guess that the burnt fluid could be a result from this abuse your transmission is going through. When you're in gear at idle the only thing in the transmission that's spinning is the pump. So when you put it in drive, your malfunctioning torque converter is locking the rear axle which isn't spinning with the engine which is. That's just like revving the engine to shift into gear. My WAG is that this could be causing your burnt smelling fluid. Of course I could be completely wrong, transmissions mystify me.
The problem with your torque converter could be either electrical or a failed torque converter. Considering how this only does it under certain circumstances I think it's an electrical issue; your torque converter doesn't care whether your transmission is in forward or reverse. Have you had your truck scanned with a good code reader that's capable of reading transmission codes?
I think you hit it right on with the worn seals. This thing has had a stock cooler on it for 165,000 miles, and I know it's been overheated on more than one occasion, so the seals are probably shot.
on
Sounds like it's time for a tranny/TC replacement or rebuild. The TC has always been a weak link in that tranny. I went with a www.suncoastconverters.com rebuilt tranny and TC; it made a world of difference on my 2002 and it was going strong when I sold mine at 185k.
on
Yes, I would be concerned. It's one thing to drive a couple hundred miles on a "maybe" tranny, but 1500 miles to Jackson Hole? Forgetaboutit, no way if it was me. If the tranny does explode, you will have so much crap in your lines that you'll never get it all out even with extra tranny filters. Much better to bite the bullet and get a bullet proof tranny anf TC from Suncoast and coast for another 200k without a worry, IMHO.
Pap
Pap
jbravata2
11-20-2014 07:05 PM
djmichael24951
04-05-2014 04:35 PM
PW01
01-04-2009 07:54 PM
redneckdieselmechanic
02-17-2002 10:04 PM
