6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2008 F350 chip questions
Old 07-12-2013, 01:09 PM
Nickf1989's Avatar
Nickf1989
Nickf1989 is offline
I have an 08 F350 6.4L and I'm looking at putting a chip in it. I have 164000kms on it, standard trans with the original clutch still in it. I'm wondering what chips work well with my truck and if it would be wise to do my head gasket and head studs, as well as my clutch, the trans is still very strong and the clutch feels good. Truck doesn't leak a drop, no oil coolant water etc..any suggestions and tips?
Old 07-12-2013, 01:18 PM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
Moved to the 6.4 forum
Old 07-12-2013, 08:19 PM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
Chip it, are you going to do truck drags>>no, find a tuner, delete it if that's what your plans are and drive it. Run it on a tuner on no power or low power you should be OK.
There are also on delete tuners that sound like that work fine, that's a choice you'll have to make.
Old 07-12-2013, 09:29 PM
Nickf1989's Avatar
Nickf1989
No I won't be drag racing, I am primarily looking for a chip that will give me more torque and more mileage as I use my truck to tow for work quite regularly. Any suggestions on what chips work well with my truck? I am planning on doing a cold air intake DPF delete and the chip. Any suggestions on intakes would be greatly appreciated.
Old 07-12-2013, 09:33 PM
Nickf1989's Avatar
Nickf1989
Also would I need to upgrade my fuel pump, fuel rail and injectors?
Old 07-12-2013, 09:58 PM
RM2738's Avatar
RM2738
RM2738 is offline
Nope. Just a simple Tuner (H&S or Spartan) and you'll be fine. Try the Search Function. There are dozens and dozens of threads on this topic.
Old 07-12-2013, 10:23 PM
GHeTTo JOe's Avatar
GHeTTo JOe
GHeTTo JOe is offline
i think depending on how high you turn it up (500rwhp very easily attainable) you will need to get a better clutch.
Old 07-13-2013, 09:41 AM
Nickf1989's Avatar
Nickf1989
Where would I find a clutch kit with full Kevlar buttons? I have been to numerous sites and can't find any with full Kevlar, the best I could find was Kevlar and ceramic buttons but they're only rated for 400hp at the flywheel and 800ft/lb torque.
Old 07-13-2013, 12:01 PM
Nickf1989's Avatar
Nickf1989
Also, back on the topic of chips. Is an H&S mini maxx compatible with a standard trans? H&S says that the mini maxx is designed to work with Ford's Adaptive Memory system which I'm assuming is only on the automatic transmissions. I was also wondering of there is a way to elimate the defuelling mode that the chip has, as it will obviously be unnecessary with a standard. Will this work on a standard trans or is there a way to turn off any transmission tuning aspects and the defuelling program of the mini maxx?
Old 07-13-2013, 12:41 PM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
If you don't have.an auro I see no reason to worry about it. Just bypass the transmission setting. You should be fine.
bc56845
12-15-2006 03:31 PM
Rich in CO
03-06-2006 10:59 PM
yukonsly
12-30-2005 08:35 AM
royoboy
Computer Chips & Tuners
11-15-2005 02:25 PM
big inch
09-23-2005 09:20 AM
Quick Reply: 2008 F350 chip questions
