1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Air Suspension , Height Sensors
Old 01-05-2017, 01:52 PM
Emiland's Avatar
Emiland
Emiland is offline
Dear,
Please help to solve height sensors "angle problem"..
I have sensor , but module detect error, that height sensor angle / axle is not in right possition.
How can I detect right position of angle of sensors?
or have you any information that how I have to replace , for example, rear sensor to front right or left.
another question where can I buy sensor for New oem or dorman REAR sensor?
Lincoln Navigator 2004 year
Old 01-05-2017, 05:24 PM
lincolnshibuya's Avatar
lincolnshibuya
lincolnshibuya is offline
you need a high end scanner (shop or dealer) to figure out which sensor (there are 3, 2 at the front 1 at the rear) normally they are unreliable POS that costs so much.
you can buy the sensors at amazon or ebay. dorman is the cheapest at $100 but quality is questionable so better stick with OEM if you have deep pockets.
https://www.facebook.com/diyLincolnNavigator/
Old 01-27-2017, 12:03 PM
outlawspeeder1's Avatar
outlawspeeder1
outlawspeeder1 is offline
What scan tools work with this.
Old 01-28-2017, 10:21 AM
alloro's Avatar
alloro
alloro is offline
Received 4,196 Likes on 2,432 Posts
As far as I know, only the $3,000 ones the dealers have.
Old 01-30-2017, 05:48 AM
rowekmr's Avatar
rowekmr
rowekmr is offline
I bought Dorman and installed both truck didn't respond. Had to end up getting OEM ones at the dealership to get truck suspension acting right again.
Old 01-30-2017, 10:10 AM
alloro's Avatar
alloro
alloro is offline
Don't sweat it, you're not the only one to have this same result with the Dorman sensors.
Old 02-08-2017, 06:40 AM
rowekmr's Avatar
rowekmr
rowekmr is offline
Wished I would have known before. I am starting to do small DIY projects and am amazed how many aftermarket parts don't work or have a reputation not to work. Its a shame so much money is wasted/stolen from consumers.
Old 02-16-2017, 07:38 PM
lhud's Avatar
lhud
lhud is offline
I just purchased a air suspension compressor from Arnott and they are an excellent go to. Customer service is top notch and knowledgeable. I think their air suspension parts are not too expensive. Another go to would be ID Cardid and they are carry Arnott parts that are cheaper than direct from Arnott website.
Something I forgot to add is that many folks are going to the conversion kit of coil over shocks. This is much cheaper and the only draw back is you will continue to get that air suspension warning light on the dash. However, you can turn that switch in the back off and it is easily canceled each time you start the engine.
Take a look.
Rumble phish
2004 - 2008 F150
17
12-20-2018 09:09 AM
KodiakF250
6.7L Power Stroke Diesel
05-25-2018 11:33 PM
mikerans
18
03-20-2013 01:00 PM
___
Aerostar
05-18-2008 05:48 AM
Rubicante
04-20-2000 08:52 PM
Quick Reply: Air Suspension , Height Sensors
