Wheel studs for alloy wheels on a D60 rear
Old 07-10-2013, 06:51 PM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
Hi All,
What wheel studs do you use for thicker aftermarket alloy wheels on a Dana 60 rear axle with drum brakes?
About the closest thing I can find is this....
http://www.summitracing.com/parts/sum-910104/overview/
The knurling is too close to the head and it doesn't have the .634 diameter shoulder that helps lock the drum in place.
Thanks much!
Old 07-10-2013, 10:12 PM
lafermedavid's Avatar
lafermedavid
lafermedavid is offline
Dorman
not sure about your after market wheels,but I used Dorman for my new studs 1/2 or 9/16
Old 07-11-2013, 01:26 AM
tude's Avatar
tude
tude is offline
Just go to a tire shop with your rim, and a lug nut to get the size if you don't know it for sure.
I would say go to the parts store but this is exactly what I did. I got 4 at napa, 3 at autozone, 8 at orielies.... Then thought oh wait what about a tire shop
Parts store- roughly $2.25-2.50 a lug nut
Tire shop- $1.15 each
Old 07-11-2013, 10:05 AM
jeff14346's Avatar
jeff14346
jeff14346 is offline
I put oem 16 alloys from 96 f250, very close fit on front calipers, but lucked out did not need to replace the lug studs. hit up local tire shop and got 32 lug nuts.
Old 07-11-2013, 11:08 AM
tude's Avatar
tude
tude is offline
I just put 16.5s on my 95f250.....
Old 07-11-2013, 11:59 AM
AK FORD GUY's Avatar
AK FORD GUY
AK FORD GUY is offline
Originally Posted by Tomahawk
Hi All,
Thanks much!
This is the style I used on my 2wd 76 F250 when I put the 95 F250 aluminum wheels on.
http://www.ebay.com/itm/20-ET-E-T-OPEN-SHORT-LUG-NUTS-WHEELS-5-LUG-1-2-THREAD-STUDS-33-SHANK-4703-/380484560051?hash=item5896a5a4b3&vxp=mtr#ht_2314wt_1101
The extended thread portion engages extra threads so that it gets full thread holding power. The stud doesn't even protrude past the lug nut, but still has full holding power due to the extended inner section.
This is my second year running these and have had no problems at all.
Old 07-11-2013, 04:08 PM
tude's Avatar
tude
tude is offline
Broke your center caps too didn't ya lol
Old 07-11-2013, 04:21 PM
AK FORD GUY
Nope, these are from the trucks that have the sterling rear end and the rear cap is HUGE and the front cap was from a 4x4, so I just left them off and saved them for if I ever wanted to put the wheels on my 4x4.
Old 07-11-2013, 06:50 PM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
Well, no luck at 3 auto parts stores and one tire garage. So I looked through the ARP catalog and found their PN 100-7077, it looks good and the measurements are correct, but the price...13 bucks each...holy cow.
ARP ARP 100-7707 Automotive Racing Products Ford Front Disc Brakes Whee - Gifts - Giftable Items - All Giftable Items
ARP 100-7707 ARP Wheel Studs
Old 07-11-2013, 08:04 PM
410 Highboy's Avatar
410 Highboy
410 Highboy is offline
I got mine from Carquest . Installed 96 F-250 Aluminum wheels .$2.00 or less each . Had to get different lug nuts that would seat properly .
SatinBlack03
1999 to 2016 Super Duty
04-05-2018 10:27 PM
JesterPgh
03-31-2009 07:32 AM
Welsch69
04-02-2008 02:31 AM
metal13x
1997 - 2003 F150
10-21-2007 03:27 PM
Quick Reply: Wheel studs for alloy wheels on a D60 rear
