6.0 trans cooler install question
My 4R100 is in a shop (03 250SD 6.8) having the seals replaced. I've purchased a 6.0 cooler for a backup. Where can this be installed? In front of the radiator is a power steering oil cooler. Wondering where those of you that installed the 6.0 cooler put it..thanks
What you are probably looking is the orig 6.8 trans oil cooler. There is a cooler below that mounted at a slight angle, and smaller, that is the p/s cooler. The 6.0 cooler will basically "bolt in place" of the orig trans cooler. Biggest difference is that the fittings point straight down on the bottom instead of coming out on the passenger side of the cooler. And the hose is 1/2" instead of 3/8".
There are plenty of threads on here aboot the 6.0 install, use advanced search or Google and you should find instructions and pics easily.
I found this link on a different forum. It's very well done.
https://docs.google.com/viewer?a=v&p...MGM2YzhiYTliZQ
december45
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
03-15-2020 05:25 PM
