July, 2013 Junk Yard Wishlist
This was a neat idea, thanks again to lgwilson for suggesting this!
Last month's will be closed.
Post your wants & needs here, even if they were on last month's list; there's enough chatter on the old one it gets hard to know if somebody is still needing a part or not without reading through the entire thing.
Please keep monetary-transaction talk amongst yourselves - in PMs or e-mail.
It's fine if we want to give/sell things to each other but we can't be running a Flea Market or Auction House here, that's against the spirit of what we do here - people helping each other.
You might also check out the 80-86 Truck Parts - Free to a good home thread.
-chris
-chris
i am looking for a ds2 swap. wiring harness, Distributor,Module,ignition coil with bracket, non feedback carb. for my 85 f150 300 i6 4 Speed Transmission, Four Wheel Drive.
i would be willing to trade my TFI-IV ignition, EEC-IV engine computer, and feedback carburetor along with the emissions stuff i will no longer need, minus the air pump as it is locked up. or pay $ if the price is right.
No longer needing these parts
Last edited by e6ug; 07-24-2013 at 12:42 AM. Reason: No longer needing these parts
I have an old crappy truck outside i think i have what you want, its a black bezel, if i remember correctly... where are you? if its close enough i can send it too you , only problem is that the two top tabs are broken but its not hard to fix those
Shocks and add a leafs
I would really like to buy some used but in good shape shocks for a stock hight 86 f250. I'm also very interested in buying some front aals to level it out. Let me know what you got! Thanks
I am looking for a combination throttle cable bracket/cruise control bracket that bolts to the intake manifold for a carbureted small block 1982 - 1985 F150.
I think I have a couple of 1986 3 button clocks, they may need the contacts on the buttons cleaned.
A stock factory radio for my 85 f150, if someone wants a newer aftermarket cd/mp3 player I would gladly trade them for a working stock unit. But will pay $$ for the right price as well.
CLT, unfortunately I sold mine a month or so ago. Did you have the switch and governor? If you added it, did you ground the switch body? As far as the governor goes, any truck up through 91 with intermittent wipers uses the same governor, up through 79 the wiper switch grounds to the dash, 1980-91 it has a ground wire due to the plastic mounting areas.
Also, while not an 80-86 part, its going to my 81 F150... i am looking for a set of 87-91 blue door panels, crank window, manual lock, with the XLT package, so it has the lower door panel pockets.
