July, 2013 Junk Yard Wishlist
I got a brand new Accel super coil for the TFI setup and I also have the TFI distributor and map sensor. Also I will be removing the EEC controller and associated wiring harness. Send me a PM if your interested in anything.
The only difference I see is yours says E/T and mine says E-TIME on the middle button and it looks like there is something to the right of the setting buttons on yours.
I listed this sometime back without response, so I will try again.
I am looking for the pre-EGR carburetor adapter [goes between the carburetor and intake manifold] for a 300 six. Thanks!
1980-1982 and 1983-1986 uses a different style of clock, they both work but 80-82 uses two connectors and 83-86 uses one.
#29
Looking for Front center caps for a 4wd f-150. Only need the fronts, bought some wheels off a 2wd.
Also window cranks and red door arm pads for an 86 XLT lariat.
If anyone finds them, please remember I'm a cheapo :P
#30
I'm building a truck out of 3 different ones, so I'm basically parting out 3 partial trucks.
I have the 300-6 perches, full 300-6 DSII wiring with a custom plug-n-play HEI module (no distributor or coil, they went with the engine), and 2 intermittent wiper setups.
Would PM but it seems I don't have enough posts yet. I will keep working on that
