Ford e150 ECU location
Old 06-30-2013, 11:12 PM
coolfeet's Avatar
coolfeet
coolfeet is offline
I have been looking for several months for the location of the vans computer. I think it's called either the ECM or ECU. Could some tell me where this unit is located? A picture would be helpful.
Thanks!
Old 06-30-2013, 11:15 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,590 Likes on 1,064 Posts
What year is the van?
Old 07-01-2013, 02:36 PM
coolfeet's Avatar
coolfeet
coolfeet is offline
1998 4.2 l v6
Old 07-01-2013, 03:46 PM
Mark Kovalsky
I think that year it is below the brake master cylinder. I don't have a photo of it.
Old 07-01-2013, 08:08 PM
coolfeet's Avatar
coolfeet
coolfeet is offline
I will look under the brake master cylinder. I will have to remove the windshield washer reservoir.
Old 07-01-2013, 11:15 PM
Club Wagon's Avatar
Club Wagon
Club Wagon is offline
Hope you meant "been looking for several" MINUTES?
Try looking next to the MC, toward center of van. The computer mounts thru the fire wall. Basically only its large, bolted, umbilical plug is under the hood & the computer's guts are inserted thru firewall, inside the bowels, behind the dash.
Old 07-02-2013, 08:20 AM
coolfeet's Avatar
coolfeet
coolfeet is offline
E150 Club Wagon computer location
I was looking at installing a performance chip for mountainous driving. We use the van for camping. It may be more trouble than it's worth. I have the 4.2 l v6. Most of the time I turn off the O/D when driving in the mountains.
Old 07-02-2013, 09:00 PM
Club Wagon's Avatar
Club Wagon
Makes no difference why you were looking for your van's brain. It's still in same location.
Kind of surprised they even made a performance chip for the 4.2 V6?
Suggest you post a link to the item you're considering, so those with V6 experience can chime in on its maker's claims. May help you decide IF "It may be more trouble than it's worth"?
Note that it apparently isn't much trouble for the average Do It Yourselfer to install a typical performance chip.
kvr901
06-20-2019 04:37 PM
josmo
09-08-2004 06:15 AM
Thudpucker
12-16-2001 11:26 PM
Quick Reply: Ford e150 ECU location
