Head bolts reusable?
Old 06-30-2013, 10:01 PM
truckpastor's Avatar
truckpastor
truckpastor is offline
I can't seem to search very specifically in this forum. In the case I pull my yblock heads off for service...are the bolts reusable? Can't find a bolt set for sale anywhere like other engines I've worked on.
Old 07-01-2013, 09:41 AM
Gregxlt's Avatar
Gregxlt
Gregxlt is offline
I'm not sure, maybe ask over on the Y block forum. I know ARP make a set, Mummert's has them for sale.
HOME Y
Old 07-01-2013, 10:29 AM
truckpastor
thanks...I also came accross this set Ford Y block page 272,292,312 cylinder head bolts,dowel pins and freeze plugsFord Y block page 272,292,312 cylinder head bolts,dowel pins and freeze plugs for sale for $90.00 seems ridiculous for pieces of metal. BTW I haven't pulled head yet, but due to my INTJ personality type I over analyze everything and plan ahead just in case. I wan't to know what surprises may creep up.
Old 07-01-2013, 10:38 AM
hiball3985's Avatar
hiball3985
hiball3985 is offline
I've reused Yblock headbolts all my life without a problem
The following users liked this post:
Old 07-01-2013, 04:51 PM
spurredon's Avatar
spurredon
spurredon is offline
I have not rebuilt a Yblock but if I were to, I would reuse the head bolts. They were made of real stuff, not like the modern day disposible ones! I have reused the bolts from a 223 in-line and a 352 a few years back without incident.
Old 07-02-2013, 07:29 AM
Walston's Avatar
Walston
Walston is offline
I reused my head bolts when I rebuilt my Y-block with no problem. I am an engineer and yes the bolts are stretched a little when torqued and in a perfect world you should replace them. However, unless they have been torqued and un-torqued many times, over torqued or you are building a race engine with high compression, there is no real problem reusing them. The torque numbers are not that high and the compression is not that high. My opinion, you mileage may vary.
Old 07-02-2013, 06:04 PM
spurredon's Avatar
spurredon
[quote=Walston;13304898] I am an engineer quote]
You kind of disqualified yourself with that remark in my view!
Old 07-03-2013, 05:45 AM
Walston's Avatar
Walston
Walston is offline
[quote=spurredon;13306419]
Still laughing......
Been a member of FTE for nearly 10 years and it is the first time I admitted it....LOL
Old 07-03-2013, 10:23 AM
truckpastor
thanks guys. I'm used to the newer "torque to yield" bolts that always need replaced. I was shocked when changing a head gasket on my taurus a year ago how much they stretched compared to the new one's length!
Redtoga
11-15-2013 10:14 AM
6point0
05-09-2010 03:30 PM
john fin
06-20-2008 05:19 PM
josmo
11-09-2006 08:28 PM
79F150400M
06-30-2004 01:00 PM
Quick Reply: Head bolts reusable?
