Head bolts reusable?
I can't seem to search very specifically in this forum. In the case I pull my yblock heads off for service...are the bolts reusable? Can't find a bolt set for sale anywhere like other engines I've worked on.
I'm not sure, maybe ask over on the Y block forum. I know ARP make a set, Mummert's has them for sale.
HOME Y |
thanks...I also came accross this set Ford Y block page 272,292,312 cylinder head bolts,dowel pins and freeze plugsFord Y block page 272,292,312 cylinder head bolts,dowel pins and freeze plugs for sale for $90.00 seems ridiculous for pieces of metal. BTW I haven't pulled head yet, but due to my INTJ personality type I over analyze everything and plan ahead just in case. I wan't to know what surprises may creep up.
I've reused Yblock headbolts all my life without a problem
I have not rebuilt a Yblock but if I were to, I would reuse the head bolts. They were made of real stuff, not like the modern day disposible ones! I have reused the bolts from a 223 in-line and a 352 a few years back without incident.
I reused my head bolts when I rebuilt my Y-block with no problem. I am an engineer and yes the bolts are stretched a little when torqued and in a perfect world you should replace them. However, unless they have been torqued and un-torqued many times, over torqued or you are building a race engine with high compression, there is no real problem reusing them. The torque numbers are not that high and the compression is not that high. My opinion, you mileage may vary.
[quote=Walston;13304898] I am an engineer quote]
You kind of disqualified yourself with that remark in my view! :-X04:-X04 |
[quote=spurredon;13306419]
Originally Posted by Walston
(Post 13304898)
You kind of disqualified yourself with that remark in my view! :-X04:-X04 Been a member of FTE for nearly 10 years and it is the first time I admitted it....LOL |
thanks guys. I'm used to the newer "torque to yield" bolts that always need replaced. I was shocked when changing a head gasket on my taurus a year ago how much they stretched compared to the new one's length!
