Needing the pulley and bracket and bolts that adjust the belt on a 1987 Ford F800 Air pump. The person that put the motor in this truck did not put this bracket and pulley back on the 7.8 in my truck. They found a belt they could just roll on the pulleys and let it go. So now in search for all the hardward and pulley along with the bracket that holds that pulley. I have the block the adjustment bolt goes through and that is it.
Anyone have one for sale?
Pete
Pete
What air pump are you asking about, what's its function?
Yes Sir, But may have one found. Will know for sure after while.
Pete
Please let me know forsure if you do get one, so I won't have to look up all the fracatta part numbers, posting them here and then search for the parts and list the sources, posting them here.
Bill found a pair of used ones online. Will have one heading this way first of the week.
Again thanks for all your help.
Pete
Parts showed up today. Will try to get them mounted next week. Soaking all of them in oil. Will then take them out and clean again along with painting them.
Pete
