Tie down hooks
07-01-2013, 09:46 AM
Tie down hooks
My dad has an 07 f150 and it has hooks inside the bed to tie things down with. They're extremely handy, and I was wondering if there was an easy way to install some on my bed.
07-01-2013, 10:43 AM
I just went to the junkyard and found some. Drilled the holes, bolted them in and done. One in each corner & one on each side over the wheel well.
07-01-2013, 11:00 AM
Does the side of the bed flex any when you pull them tight?
07-01-2013, 02:19 PM
No, mounted to the flat spots in the bottom corners of bed. Pretty solid, ones over the wheel wells get dinged up from throwing in firewood.
07-01-2013, 02:50 PM
I may now install them over the wheel wells and only do the corners. I wish I had time to throw them in before I'm done moving.
07-01-2013, 03:44 PM
I got some in a package with some ratchet straps. I put the on the inside of the bed on the bed rail. All I had to buy was some lag bolts
SDTruckMan
2017+ Super Duty
04-17-2018 11:52 AM
ddan342
05-03-2016 06:30 PM
Offroadracer426
03-18-2010 10:25 PM
spdmpo
1999 to 2016 Super Duty
04-23-2009 10:59 PM
mtondreo
1997 - 2003 F150
08-20-2008 05:55 PM
