Wanna be a powerstroke man
Alright fellas. I have been down in the pre powerstroke forum for a little while now. And for a good while now i have been looking at getting a new truck, but have just been narrowing down what i want. Was thinking a 99-03 PSD but right now their just really expensive. for the mileage i would like to find.
I've kinda narrowed my view to a 94.5-97 model f350 single rear wheel.
Crew cab
I have done a little bit of skimming over of the engine differences between the OBS and super duty engines, things like Turbo, Injectors, INTERCOOLER.
But i mean, it's still a 7.3l International.
I'm not really sure whats the highest HP anyone on here has seen out of on of the 94-97 trucks but i don't expect no 500hp.
I would love an automatic, But i would also love to tune it intake exhaust and MAYBE injectors. if i did that MAYBE intercooler.
But what kind of horsepower can we push with these transmissions before we have to do work on them? as far as the automatics go?
Like i said i wanna add a little bit of power to it, somethin to play around with at stoplights haha, but i wont be drag racing. And when it gets to the point that you have to upgrade transmissions and torque converters thats when it gets uneconomical to me and i should just buy a newer truck.
So lets hear it, maybe max HP out of some of this model truck, HP limits on the stock trannys? compared to the ZF-5?
(P.s dont tell the IDI guys im up here)
Crew cab
Crew cab
Crew cab
I wouldn't put much more than stock to it without an upgraded valve body or shift kit and cooler at the least. I ran with my setup (stock turbo at the time) for a couple years with just a valve body and cooler upgrade and did fine. I freshened it this winter and put a billet converter in now.
If you drive normal and don't hotrod around the auto will work well. If you need to play at too many stoplights if you do an injector upgrade, I'd not expect it to last too long. Pulling hard will work it more too of course. Mine had 155k on it before I freshened it, and it was still working ok. Converter was getting weak though.
I hate to say it...I will only have an auto. But the autos in these can not deal with massive power gains..in stock form they are adequate.
That being said...I won't have anything else but my cc auto.I'm fairly easy on it and its fairly stock.
When I do upgrade....it will get swapped for a built unit.
Intercooled is for the turbo air pressure. Trans cooler is for keeping the trans cool which we have to add a bigger one then stock. The stock one sucks. The SD models have a 4R100, I think that's what its called, it might be a little stronger but not much. I think it can be adapted to our trucks but not worth the trouble I have read. I don't know for sure though.
I made 518hp/995tq a few months ago on the dyno with my ZF5 and a dual disc clutch. With an auto, you'll need some trans work if you upgrade the injectors. A better torque converter, valve body, and cooler helps quite a bit, but eventually I'm sure a built unit will be needed.
FYI... The SD and OBS do have slightly different cranks and pistons, but have the same connecting rods up to 2000. Both cranks and pistons are strong pieces and are equally reliable. The connecting rods are the weak point in the bottom end and usually let go around 600hp.
I figure it's about 15%-20% stronger in stock form. you can use it in our trucks but you have to change out a valve in the main pump and the solenoid pack and wiring (again iirc).
Richard
haha, naw man its amazing the kind of things Justin and all the guys down there have done for our old trucks. It's just for what i want to do my truck isn't a great candidate, and yes i could just as easily sell mine and buy one in better condition, but i just don't have the skills or, i don't wannt say money, but i don't have the money to put into those trucks to get the kind of power justin is putting out. Hey, i figure as long as it says 7.3l on it. we're all family at the end of the day.
Besides, dad wants my truck, she'll still be in the family
Thanks for all the info guys! leaning towards a ZF5 im thinkin
This is just my opinion.. But stay the heck away from the auto's! LOL!
I am with everyone on the power hold up on these E4OD's. After going full tilt on my swap out on my 7.3, the auto in mine lasted one week. Now I have a truck to go fetch several states away! LOL! I cant even give away my E4OD, so I am stuck with a heavy paper weight!
I have almost 275k on my e4od...
richard
