suggestions for steering gear box
I've haven't been on here in a while so I don't know who will chime in on this but here we go. The steering box is prone to leakage due to the design that ford incorporated. The bottom seal is just that, it's a seal. As you turn te shaft inside the box experiences forces that cause that seal to slowly but surely wear away. Red Head steering takes your box and machines it so that a bearing can be placed where that seal goes. I haven't done it personally but from what I've read it does wonders. Long story short you can keep replacing the seals or send it off to red head.
http://www.redheadsteeringgears.com/...facturing.html
Re-Manufacturing - Red Head Steering Gears
what the price is?
There are no bearings on the sector shaft, it rides directly on the housing.
And, so-called auto parts store 'rebuilt' gearboxes are nothing more than resealed gearboxes, so you don't want one.
Red Head takes the housing, machines it, installs the needle bearings that Ford omitted, so they could sell a gazillion sector shaft seal kits (same: 1965/2002).
Contact Red Head for their price.
I have heard Redhead has a box for bumps that has car parts in it to reduce the number of turns lock to lock giving a quicker ratio. You may want to look into it since you are planning in replacing your box. Hopefully someone who has bought 1 will chime in with pros/cons on the box. I have rack & pinion so this is nothing I have personally dealt with just read about.
Of course it's leaking again, because the Ford/Saginaw P/S gearbox has a flaw.
Red Head takes the housing, machines it, installs the needle bearings that Ford omitted, so they could sell a gazillion sector shaft seal kits.
Dunno how the housing, steering and sector shafts from a car could possibly work in an F100/350.
D3AZ-3C538-A (replaced C5AZ-3C538-A) .. Master Seal Kit replaced by two kits:
D7AZ-3E501-B .. Sector Shaft Seal Kit & F3AZ-3E502-A .. Input Shaft Seal Kit. Last year these two kits were used: 2002, on Crown Vic/Mercury Grand Marquis.
Rack & Pinion steering introduced in these two in 2003.
Gordon M
13
09-16-2018 10:36 PM
mjr46
18
10-16-2016 09:37 PM
fordguy98
05-30-2016 09:25 PM
bbf150
08-18-2015 06:53 AM
