Pic request: Dealer AC Bracket
My truck has dealer added AC, but the comp bracket looks like a hacked together, backyard, pos. Even uses pipe nipples for spacers! Anybody else have dealer air on their 300? I could really use a pic of a good example to redesign mine. Mine uses the Sanden compressor, but I also have a York I may use. Perhaps a later, factory bracket may work? Were they combined with the steering pump, or did they have separate brackets?
I tried the 73-79 forum too, without results.
I just happened to have this pic on photobucket. If you need a better pic, I can get you one tonight. The support on the back of the bracket that goes to the block is spaced away from the block by about a dozen fender washers. There's also one more bracket that goes from the upper driver's side of the compressor to the mounting bolt for the coil.
John89
12-24-2017 07:13 PM
Sam's1967
284
03-31-2017 12:43 PM
Rodney R
06-07-2015 05:54 AM
abyars111
03-23-2015 10:23 AM
