time for an egr valve?
Old 06-27-2013, 05:32 PM
octaneforce's Avatar
octaneforce
octaneforce is offline
my truck started running really rough earlier today and the cel came on for a moment when it happened. i checked the codes and this is what it threw:
181- (trucks only) HEGO (HO2S) sensor fault unable to switch/lean during part throttle
334-EGR closed valve voltage high
556- fuel pump relay primary circuit fault
the o2 sensor was replaced about a year or two ago. also, sometimes when i start it after its been sitting, it will die and then i have to start it again. which probably has something to do with code 556. where is the fuel pump relay? the truck is running better now, it seemed to clear up as i drove.
Old 06-27-2013, 05:54 PM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
The FP relay should be located under the hood on the driver side, near the firewall. About in the same area as your diagnostics plug, but which one it is I can't say for sure.
I've been sorting out a code 334 on my 1991 5.8 lately. What you'll want to do is backprobe the harness for the EVP sensor and see what it's reading at idle. Then unplug the vac supply and see what happens. If the voltage stays the same, either the EGR is stuck open or the sensor is bad. If it drops significantly, your EVR (EGR vacuum regulator [also called a solenoid]) is likely bad. Fuel Injection Technical Library » EGR Vacuum Regulator (EVR) In my case, I had .92 volts at idle, and it dropped to .45 volts when I removed vacuum, so my regulator was bad.
Good luck.
Old 06-27-2013, 11:41 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
Fuel Pump Relay location info:
courtesy of subford
Old 06-28-2013, 02:50 AM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
I've got the code 556-Primary Circuit issue code also..
What does it ACTUALLY mean? I mean, which wires/circuit is having issues? And what can those issues be?
Right now, I'm getting the codes for the engine running lean (Has a vacuum leak upstream of the Oxygen Sensor, which I'm sure is not helping the case) and every so often, I can smell 1/2 burnt fuel from the exhaust.
But otherwise I'm still getting "Decent" mpg..
Old 06-30-2013, 03:45 PM
octaneforce
my problem is getting much worse. when i start the truck in the morning in dies and/or runs rough for a few minutes. it seems to clear up once its warm. il have to start checking voltages. the egr vaccuume solenoid and egr sensor have been replaced within the past year. i think the egr valve is getting hung up. it looks original. what symptoms would a bad fuel pump relay cause?
couchsachraga
06-05-2015 04:38 PM
smurf91
1978 - 1996 Big Bronco
21
04-20-2012 11:04 PM
court1100f
09-11-2010 05:52 PM
boggerted
02-11-2010 01:44 PM
bumper.45acp
01-12-2008 08:47 PM
Quick Reply: time for an egr valve?
