Code 22 won't go away
Hey I built this 5.0 for my 92 f150 and I put it in and got a list of codes, I've replaced the tps, egr, and checked for vacuum leaks using a propane torch. I got rid of all codes except code 22 map sensor out of range. And the truck is idling really rough, I've been trying to figure out what to do for a couple days now. I changed the map sensor and it didn't change anything. Anybody have any ideas
And using what to read the Codes? I suggest you stick to the KOEO tests/CM display until you can get a System Pass code of 11, then repeated (11), for both the KOEO tests and CM display. You may need to clear the CM by pulling the jumper when the codes are displaying.
I caution you if you are counting flashes to read the code to not misinterpret the System Pass code of 11/11 as a Code 22.
It's time to start tracing put wires to verify the MAP signal is getting back to the PCM as well whether or not it is getting VREF from the PCM.
For reference:
Fuel Injection Technical Library » Manifold Absolute Pressure Sensor (MAP)
Ford Fuel Injection Truck Computer pinouts
For reference:
Did you replace an old 5.0 with your built 5.0 ????
Hopefully not an old 4.9 with a built 5.0.......that'd cause some computer issues.
Bob
