2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
What brand of shocks to use?
Old 06-27-2013, 09:03 AM
jp4lsu's Avatar
jp4lsu
jp4lsu is offline
I need to replace the rear shocks on an Expedition Limited with the coil spring set up. What brands should I look at?
Autozone and O'Reillys carry Monroe and KYB. Are these acceptable?
Bilsteins?
Eibachs?
Would these be better for ride and durability.
Old 06-27-2013, 11:25 AM
Beechkid's Avatar
Beechkid
Beechkid is offline
with regards to shocks.....IMHO:
1) Koni- Excellent for racing applications- overpriced for street applications
2) Tokico, QA1 & Bilstein- A very good shock for street/strip applications. If you are running very stiff tires on the street (such as Bridgstone or tires with profiles shorter than 50 series), these provide the extra give that you need for both comfort & stability
3) KYB- A very good shock for street/strip applications. If you are running a softer tires on the street (such as BFG or tires with profiles not shorter than 50 series), these provide the extra stiffness that you need for both comfort & stability. The Exel-G’s (formerly GR-2) are the equivalent to the Edelbrock IAS automatic adjusting units. Overall, stiffness between the Gas-a-just and the GR2’s are the same, the difference is the GR-2's valving which stiffens things up from a oem setting to that of the Gas-a-just units.
4) Gabriel- A very nice good quality HD OEM replacement type unit.
5) Monroe- stay away from that junk!
Old 06-27-2013, 11:48 AM
jp4lsu's Avatar
jp4lsu
jp4lsu is offline
Thanks Beechkid.
Sounds like KYB might be the choice here. I'm leary of Monroes and the big brands that these parts stores carry. So I felt I needed to ask about shocks since I'm not that well versed on these components.
The Expy has 20" wheels with 55 series BFG's, so I think a KYB shock should be a good selection based on your analysis.
Thanks and feel free to provide more info and analysis. Good stuff
Old 06-27-2013, 02:52 PM
Big Bad's Avatar
Big Bad
Big Bad is offline
Bilstein HD, valving is about 20% stiffer than stock.
Being a monotube, high pressure gas shock with digressive self-adjusting valving (deflective disc), they have the same variable damping characteristics of the Edelbrock IAS or KYB GR-2, etc.
Lifetime warranty and track record is a plus.
casados303
6.4L Power Stroke Diesel
09-10-2012 01:46 PM
RedBoat
6.7L Power Stroke Diesel
32
04-02-2012 02:19 PM
thebandit343
03-15-2012 03:01 PM
Genesis
06-09-2009 02:15 PM
wreckinball
05-27-2009 12:06 PM
Quick Reply: What brand of shocks to use?
