Diesel leak under turbo -help!
I have a diesel leak on top of the engine under the turbo and behind the turbo y. Can't really tell where the leak is coming from. I was able to see a constant drip w/ the engine running using a little mirror. Do you guys have any idea what is leaking and what is required to fix it? Will I have to remove the turbo and y? (really not looking forward to that). Don't even have the first clue about how to remove those parts anyhoo. Any help would be most appreciated. Thanks. This is a 2003 F250 California style.
I guess the leak is slightly towards the passenger side. I can see one of the fuel lines coming from the fuel bowl, and fuel doesn't appear to be leaking from the line I can see (of course). Forgive my lack of mechanicaptitude, but do I just try to find both lines of that steel line, remove, and inspect? Everything is so tight under the turbo charger that I am not even sure I will be able to find the places to unhook it. Anybody know how much a new pax side fuel line costs? Can it be found after market or is that a Ford Stealer item?
Yeah, what about that clip? What is that attached to? I am going to have a really difficult time getting to two nuts that I can see. How am I ever going to get to that clip that I can't see? Tugly, thanks for the pic...I think it would be easy to get to the line if everything that is missing in your picture were missing on my truck!
Lartross,
I guess that is my question now...how do I remover the intercooler piping? The intercooler I assume is what I was referring to when I said "turboY". There are so many wires going every which way. Are the only things that are physically holding the intercooler in place, the hoseclamps? Looks like it will be a PITA to get those lower ones removed. I am sure mine haven't been removed since they were installed in 2002!
Tugly...I could order all that stuff (if I even know what half of the stuff was), and I didn't need to actually drive my truck!
First things first..get a bottle of Simple Green concentrate from wally world and a good sprayer.Use the entire bottle on your engine spraying everything(especially down in the valley). Let it set 15 or 20 minutes then hose it all down good with nozzle pressure only(you don't need a pressure washer). After it dries you will be able to see/work better.
The IC tube is as big as your arm (diameter and length). You would need a 7/16" deep socket to loosen the clamps that hold the boots to the pipe. Make note of how tight the clamps are, because you want to get them that tight again. A loose boot clamp is an underwear-soiling event. Before putting the IC tube back together, you want all mating surfaces clean and oil-free.
