Help with replacing Air Filter - P0170 P0174
Old 06-08-2013, 11:24 AM
F250_HD_Crew's Avatar
F250_HD_Crew
F250_HD_Crew is offline
Hey Folks,
I may have found the reason I have been throwing P0171 and P0174 codes.
When I went to replace my air-filter I found that two of the four threaded inserts that the bolts screw into (that hold the air-box lid on) were loose and so they were not screwed down even close to snug. So there was not not a good seal.
The now immediate problem is I can't figure out how to remove them. I just tried unsuccessfully with a small set of vice grips. I can't get a hold on them. They are circular so sliding an open end there is also not an option.
Ideas? Anyone else experience this? If so... how did you remove and how did you fix?
Thanks
John
Old 06-08-2013, 04:10 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Keep pulling up while you try to turn the bolt, that's what I did and it worked.
Old 06-08-2013, 04:44 PM
F250_HD_Crew
Found some needle nose in the garage that worked to remove. I'm pretty peached off at the garage that did this and didn't say anything about. Both sides are cross threaded. Serves me right for being so lazy on having them do it in the first place.
I stumbled onto this thread. It looks like you can not buy the just the hardware.
https://www.ford-trucks.com/forums/1...-hardware.html
Any fixes othet than zip ties or replacing the box?
John
Old 06-08-2013, 04:51 PM
Encho's Avatar
Encho
Encho is offline
I use zip ties, they work just fine.
Old 06-10-2013, 09:15 AM
F250_HD_Crew
The Zip ties did work fine... Thanks.
I did push one of the two remaining inserts out upon installation.
Cleared the codes and went for a drive. check Engine light came back on after about ten/15 mins of driving.
I am now throwing a P1151 in addition to the P171 and P174.
Old 06-10-2013, 09:19 AM
Encho's Avatar
Encho
Encho is offline
What year is this truck we're talking about? if it's the same gen as mine you either get 2 digit codes or 3 digit codes.
Old 06-10-2013, 09:44 AM
F250_HD_Crew
1997 F250 460 ci. OBD II.
John
walmill
09-27-2017 04:43 PM
asavage
Aerostar
03-21-2012 11:57 AM
brainwashed
09-14-2011 06:35 PM
kpwall
1983 - 2012 Ranger & B-Series
06-22-2006 10:32 AM
jdrose
02-21-2005 08:53 PM
Quick Reply: Help with replacing Air Filter - P0170 P0174
