want my truck back to normal!!!
92 F150 302. So I was having some idle surge and poor drivability recently. The check engine light was on and codes read an egr code, tps, and something else (done at a shop). So I also found a vacuum leak leading from the coffee can which I guess can cause the egr code? I just spliced it with a piece of rubber hose to see what I would get, so keep that in mind. Then even though my uncle (mechanic) replaced my tps, the shop said it was bad. So I put a new tps on and while I was at it I cleaned the throttle bores out pretty good. So as of the past couple days of driving, no check engine light and no "original" idle surge. However when I am driving and shift gears the rpms will spike to 2600-3000 rpms and then slowly come down but only to about 1100 rpms. If I sit in neutral the truck will eventually come down to about 800-900 I guess. So any ideas on fixing this? Could it be the half-a** vacuum line fix?
starfuryz2040
1983 - 2012 Ranger & B-Series
07-17-2006 11:29 PM
brannma
09-07-2003 11:42 PM
