How many miles is to many
Quick question I have an 06 screw with a 5.4 flex fuel motor I have had all scheduled maintenance done on time per the manual so I'm having to drive about 800 miles a week now for work so miles are adding up fast 131,000 right now when do you guys think enough is enough and she becomes unreliable and how many miles do your trucks have on them aim hoping for at least 200 to 250 thousand before she starts to become trouble for me
F150 Longevity
How many miles is enough...depends on you & of course your driving & a bit of luck ...all 4.6 's & highway kilometers....my 02 went 647,000 KM's ran like a kitten!! changed with reg. oil @ 5000km religiously...done regular tranny oil/plugs etc. of course I change out the complete front end as needed...if you don't have the cam phazer issues I think you are good to go!!!!!!!!!! my 2010 right now is kissing @ 500,000 & purring but is a slightly different build on the motor...biggest thing both trucks I replaced entire driveshafts around + 250,000km's
PS: i also got $2500.00 cdn. on the 02 when I traded it in on an 08 for the wife.....
I might add after the 02 I bought an 07 with 5.4...it went 335,000 & then one day I was sleeping in it & I inadvertingly stepped on the gas pedal wide open for a couple of min. ..it took about another 600 km...to cause the cam phazers etc. to start ticking loud enough that the knock sensors shut down the power...I chose to replace the motor with a good used 09 5.4 ...I still got it & it is around 424,000 km right know & going strong although I don't need to really drive it now!!
I've got two F150s, a 2000 with a 4.6 and a 2007 with a 5.4.
The 4.6 has 291,000+ miles on it. So far the only things, other than routine maintenance was a transmission, replaced under warranty, and the idle air controller needed to be replaced.
The 5.4 has just turned 219,000 miles and has had no problems at all, just routine maintenance.
Both have had conventional oil changes every 3000 miles. I started using 5W-30 in both once the warranty had expired.
I've changed the spark plugs in the 5.4 myself twice and have never broken any. The cam phasers are still quiet too.
I may be wrong but it seem like I read about a lot of phaser failures and valve train failures by 150kmiles. I have 105kmiles. I just replaced the injectors preemptively and the PS and tranny cooler liners lines preemptively. I have been planning on keeping it for only another 50kmiles. Should I reconsider and keep it longer?
