swaping 4spd to 5
Flexplate (flywheel) is on automatics.... is your truck a 4 speed auto or stick shift?
Cross member can be moved or modded if needed, but if you have the other one, be a good idea to use it.
On the transfer case, i'm not sure. I know on E4OD trucks and ZF5 trucks, the tcase will interchange though.
When I swapped a ZF into my '87, I needed to change the clutch hydraulic line, the crossmember, the floor insert in the cab, and the driveshaft. The original clutch and flywheel worked fine with the 5-speed. Mine is 4x2, so you would need to compare the length of each transmission to determine if the original driveshafts would work or if you would need new lengths.
Rustlin'
12-28-2014 09:16 AM
nhellman1
01-13-2011 08:50 AM
