No Mechanical Advance?
Old 06-02-2013, 09:38 PM
march's Avatar
march
march is offline
I have a new to me 78 supercab with a 460 (D3V Heads) and electronic ignition. Was playing around tonight and decided to check the timing. Removed and pluged the vac advance, rpms at 650. It's set at 14+deg initial. However when I increase rpms it doesn't move or even drops a little. I tried it with vacuum connected and it goes over 30 with increased rpms. I should have mechanical advance - right? I would check, but have never pulled a distributor apart before. Is that safe to do with the dist installed. I don't want to loose some small part into the engine.
Old 06-03-2013, 04:36 PM
mcdonaldm's Avatar
mcdonaldm
mcdonaldm is offline
easy to check. just take the dist cap off and the mechanism is sitting right there underneatht the rotor and the reluctor wheel. it is two weights with springs attached to them. manually move the weights to see if it moves the plate. lost of the emission era dist don't have a lot of mech advance built into them and the advance is pretty small. most of the advance comes from the vacuum can.
you can get new springs to change the rate. the limiting factor is if you look you will see a square window with a tab thru it on the pickup plate. this limits how much advance you can get out of the dist.
do a google search on the Duraspark II distributor. should be lots of links showing a breakdown on this distributor.
rgds
Mike
Old 06-03-2013, 08:00 PM
V10man's Avatar
V10man
V10man is offline
My dizzy was froze up also. Truck ran so much better after I installed a rebuilt one. You can try to mess with it but it was easier to just buy one at Autozone.
Old 06-03-2013, 10:29 PM
march's Avatar
march
march is offline
Thanks guys. I was able to find instructions and took it apart. It looked decent inside, but was frozen stiff. Cleaned it all up, hit it with a little lube and put it back together. Seems to move freely now. Didn't have time to play with it tonight, but will check timing again tomorrow.
azroxx
18
01-13-2019 10:43 PM
Rusty_S
16
12-30-2018 05:08 PM
rookieford
07-16-2018 04:56 PM
dusted800
03-06-2004 07:43 AM
goodyear
12-01-2002 09:12 AM
Quick Reply: No Mechanical Advance?
