1996 cc refurbish/psd swap
#31
I think if you look at the price of the hardware kit you'll need you will agree to try to reuse what you have unless the bolts are really trashed. The hardware is pretty pricy. I have all the ES bushings in the suspension now and I have the body bushings on the shelf. I think you'll like the way it rides with that stuff in there. The truck certainly does feel "tighter" with those old worn out rubber bushings out of the equation.
#32
Yeah I have a question about the rust shield too. I would like to spray the stuff onto my frame and chassis but POR15 says you need to use THEIR thinner and solvent to spray their product. I think they say nothing else will cut the stuff for cleanup. What is required for cleanup on the Rust Shield you used? Can use use regular old acetone or mineral spirits? I like the POR15 I have used and it holds up well, but doggone is that stuff expensive, let alone if I have to buy two other parts of their product line to thin and clean the stuff up.
#34
#37
#38
on
1 Post
I got the package deal right off the energy suspension site. 186 to my door.
PackageDeal053 Package Kit - Ford F250 and F350 4WD Package Kit
Or you can buy only what you need
Energy Suspension Parts: 4WD, Ford F350 4WD 1996
Bill, How hard is it to move around that stripped frame you posted a picture of earlier out of curiosity, think a few guy could muscle one around easy enough? and that rust shield is brush on ? how did you like how it came out?
#39
Me and three other guys moved the frame once, and it was all we could handle. I've moved it once since then, but I used a tractor with a front loader. I put the Rust Shield in a paint gun and sprayed two coats on, then sprayed two coats of semi gloss black enamel over it. You can brush it on too though.The frame has sat outside all winter up on horses, and I don't see any signs of rust on it yet, but if I had some of the other parts out of my shop, I would have kept it inside.
#41
I plan in just brushing mine on, POR15 is supposed to be some nasty stuff to spray, and the extra POR15 products required makes it that much more expensive.
Bill, i was looking through your thread, haven't finished yet, but how is your low dollar e fuel setup working out, still no problems with the pump/regulator ?
https://www.ford-trucks.com/forums/1...-tunes-12.html
#42
on
1 Post
Here is a link to my crew cab project. You'll feel a lot better about yours when you see what I started with! LOL! https://www.ford-trucks.com/forums/1...b-project.html
#43
#45
Bill, and anyone else with rust shield experience, how does it work over already painted surfaces. and what kind of prep is required, on their website, there is little info. I was thinking about using some grey rustshield for the underside of the cab/bed and maybe even getting some white for the rad support, or maybe il por15 that and topcoat it white, it is starting to rust, and I don't think our rust free rad supports exist any more, at least one that are for sale.
