coolant to heater core flow direction
Old 05-27-2013, 08:04 PM
chetspencer's Avatar
chetspencer
chetspencer is offline
So I'm getting ready to flush out my 292 y block which has sat for over 15 years. Does the engine coolant to heater come out of the intake manifold and back to the water pump or vice versa. Also I've read that there are coolant drain plugs or valves in the block, can you guys explain which ones they are. Thanks.
Old 06-22-2013, 08:09 PM
NONclow's Avatar
NONclow
NONclow is offline
The WP draws from the bottom of the radiator and coolant is expelled out the thermostat housing allowing coolant to migrate, by gravity, top to bottom. The coolant path for the heater goes out from intake through heater, and back to pump. There are two drains on the block, about the middle of the lower part of the block on each side. Sediment collects at the base of the cylinders, after removing plugs it may be nessesary to poke something into the passages (i.e. a small screwdriver) to initiate the drainage.
Old 06-23-2013, 12:19 PM
chetspencer
Thanks for the detailed description. The reason for my asking was I installed a filter in the heater circuit like we do on the powerstroke. It's working quite well to get the last little bits of crud out of my recently derusted cooling system.
4CFarms
02-10-2011 04:47 PM
WALJON
01-20-2008 07:37 AM
gross30
1999 to 2016 Super Duty
12-31-2007 06:05 PM
slowring
15
11-14-2006 09:12 PM
2000psd
12-27-2004 06:46 PM
Quick Reply: coolant to heater core flow direction
