86 EFI 5.0L High fuel pressure problem!
Hey guys, After having months of fuel problems I just cant take it anymore.
Every single part on my fueling system has been replace.
Rear tank
New in tank pump
In line fuel pump
Removed tank line selector located under the frame
new fuel filter
regulator
For some reason now the truck makes over 70psi. The fuel pressure gauge I have on the fuel rail actually almost wraps around if it wasn't for the posts inside the gauge. Replaced the pressure regulator TWICE because I thought they were faulty. All proper vacuum lines are hooked up as well. removing the vac line from the regulator doesn't affect anything.
The truck idols around 1500 rpm but it's running incredibly rich. Fuel actually leaks out of the tops of the injectors there is so much pressure.
WHAT is causing this!?
Any input is greatly appreciated !!
Rear tank
New in tank pump
In line fuel pump
new fuel filter
regulator
It should, but it sounds like you may have a restriction on the return side. It can regulate pressure, but if there is no where for the excess to go you can run into issues like this. As far as the leaking from the injectors, that sounds like you need to replace your o-rings. They should be capable of holding back the extra pressure by design.
Rapidrob
06-16-2017 10:49 PM
Matts85
04-25-2010 01:01 PM
sainty333
01-02-2007 02:58 PM
cougardude70
10-10-2003 11:40 PM
