Oil in my coolant 6.9
My reservoir ran over while warming up. Got to looking and there is a good deal of oil in the resevoir and radiator, no water in the oil. Iam New to diesels but ihave had head gaskets go on gas fords in the past and it was obvious. The thing that gets me is that the truck runs great. Would you guys think that it is the oil cooler. Any input would be appreciated. The truck is 86 f250 4x4 6.9
sounds like the oil cooler failed. the oil cooler is that big tube thing on the left side of the engine block that the oil filter screws onto. its a heat exchanger between oil and water, and its not unheard of for its o-rings to fail and leak as yours is, or i've heard of them corroding through.
its a little challenging to get it off the engine, but it can be done.
obviously, you want to get it fixed before driving any more, and you'll want to change the oil and coolant when you're done.
Also, the black O-rings are garbage, typ4 had a fun experience with them only lasting ~20k miles and they cracked up and leaked, make sure you get the good ones (dark blue and green) so you only have to do it once. Also check when you have it out that the oil cooler tube isn't super rusty, them rust made pinhole are a pain when you just had it out 2 months earlier.
So I pulled the oil cooler out and the o rings were hard but not cracked. So I then did the best pressure test I could on the cooler and as far as I could tell there was no leak. I put a piece of water hose in one side of the oil passage and put my thumb over the otherside submerged it in water and pressurized it with a air compressor. It would blow bubbles out around my thumb but none through the water baffles. Do you think that was sufficient? And any other ideas? I heard there is copper gaskets around the injectors that could be the cause? Any suggestions would be great but try to stray away from head gasket if you could lol.
you may as well replace the o-rings anyway. theres also a chance that one of the gaskets where the oil cooler mounts to the engine may have been leaking between its ports, i don't know if you inspected them while taking them apart, but i would suggest you go ahead and reseal that oil cooler, then take it for a test drive and check your fluids again.
