E40D TRADE TO A 4-SPEED
so i got a truck that im trading mine for. sucker has tried to run away on me multiple times now and im tired of puttin motors in it. got a 93 7.3 from my cousin. do you guys think that my 4 speed pedal set will work in the 93 which had a e4od in it. what all will i need to remove. what all will i need. also does anyone have a standard wiring harness for that year in cab the one thats in it is all melted and tore up replaced with speaker wires and was wired up to a push button start. i might just need the entire harness please let me know.
and i know its been a while since i been on
No it won't. You'll need a pedal assembly from a 92-97 Ford truck to fit that '93.
Also, if you swap a tranny 1991 and older into that '93 truck, you'll have to block off somehow the speedo cable hole the older trannies will have. This generation truck has electronic speedos reading off the rear axle.
craneman49
08-06-2011 04:30 AM
ironmanisanemic
02-18-2011 12:12 AM
keiser blade
07-12-2009 08:58 PM
