Towing a 30' 7000lb travel trailer with an 07 f350
Hello, I am new to the towing section on this site and had a question about towing a trailer. The tow vehicle is an 07 srw shortbed f350 diesel. It has goodyear dura trac tires on it, that are 3 months old. The trailer is a 99 30' Prowler weighing in just under 7000lbs. I know it should pull it but I am taking it on a 300 mile trip upstate NY. What weight distribution hitch set up should be used? What are your opinions on the tires I have?
I have towed smaller trailers and tow trucks before, but never a trailer of this weight. Thanks for any advise you can provide.
Joe
Joe
A weight distribution set up is what I would suggest.
See the link for some suggestions:
Weight Distribution | etrailer.com
This will help to level the load and keep the trailer from swaying behind you.
Also...don't forget the trailer brake controller if you don't have one.
Joe
Joe
Joe
Joe
Friction sway control bars are inadequate for longer trailers. And, they need to be set properly each time you hook up. Just a tiny bit too loose and you have no sway control at all, even with a much shorter trailer.
Reese is one of several hitch brands owned by Cequent Corporation. Draw-Tite is another of their products, but if you look close, they are the same items.
You might go look here to see what the ratings are for your truck:
2007 Ford Super Duty F250 F350 Technical Specifications
Hopefully it's correct and you can scroll down to look for your truck's specs to see how your weight ratings are (is it a crew cab or supercab or regular cab, etc... as that all affects the weight ratings)
u really need to know the actual weights - including pin weight of trailer and gvwr / gcwr of truck to be sure..
but that light a trailer - you should be good - good luck !
Congrats on your trailer and tow rig. trailer weight wont be a problem for you. as mentioned earlier you need a good weight distribution hitch and also as mentioned the #1200 lb. bars. SteveC7010 is correct, the friction plates are a guessing game for your size/ weight rig and need constant tweaking and setting. I have an 05 6.0 excursion and went with the ProPride hitch. Trailer Sway Control Hitch Guaranteed to Eliminate Trailer Sway - ProPride 3P
Ya, I know, big $$. Got it for several reasons. Short wheelbase on my ex like your SB truck. Got the whole family onboard and don't want ANY sway at ANY time. Nothing more important than the fam. And backing in to hitch is simple as the hitch moves and will still hook up even if you are off a few inches. Oh, and my spring weight bars are hooked on jacks and can be tightened/ raised with my power screwdriver. No more lifting onto the correct chain link. Hope this all makes sense. Good luck and enjoy yer camping
chado
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
18
05-18-2003 02:13 AM
