chattery clutch
Old 05-18-2013, 03:30 PM
jamhh's Avatar
jamhh
jamhh is offline
chattery clutch
I have a 59 f100 that when starting to disengage the clutch its very chattery. Any suggestions where to start. Everything looks good. I have a new slave cylinder on it. The plates look to be free of oil and grease. The system has been bleed of air?
Old 05-18-2013, 04:42 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Release bearing hub?
Old 05-19-2013, 09:19 AM
57_ford's Avatar
57_ford
57_ford is offline
Check your motor mounts. If they get loose the motor may be jumping around and just feel like a chatter. You may be able to just tighten the motor mount bolts.
Old 05-19-2013, 08:04 PM
spurredon's Avatar
spurredon
spurredon is offline
i have also seen spring bolts loose on the rear end make it feel like it was the clutch if you weren't really thinking about it.
ige1963
01-25-2015 10:23 AM
jas88
24
03-14-2011 11:29 AM
Tumblindyce
11-20-2009 04:59 PM
E30tdf
01-22-2008 10:59 PM
drillerdan
11-15-2004 08:51 AM
Quick Reply: chattery clutch
