4r100 trans FIPL??
4r100 trans FIPL??
Having downshifting problems with REbuilt transmission. Is there a FIPL sensor for the 4r100? I was told to check all engine codes first, but i just have a EBPV sensor code, but removed the valve when I installed the GT38R turbo...
Any help would be great. Thanks!
Rebuild:
- Tugger kit
- triple disc Billet torque converter
- New clutches and seals,.
- Banks Trans command module
... I also have a 6-pos tuner..
I had a Super chips tuner too and it has ALWAYS had the downshifting on acceleration on up-hill grades!! so i didnt think it could be the programmers
Rebuild:
- Tugger kit
WHAT???...
The positive has been that the transmission seems to have GREAT line pressures and shifts smoothly in all other applications except accelerating getting on the highway ramps, or cruising down some Tennessee back road that has a gradual hill that causes it to downshift until it reaches the top.
Thanks for the feedback!!... I know that Transmissions are not really a cut and dry solution with forums.
Originally Posted by TugzDzl
Maybe I should just start over, because I get all kinds of info!!..Was told the 4r100 and 4AOD was the same trans!..(sorry if its the wrong name),
but anyway, I have taken it to several places. One said nothing was wrong, could not duplicate.. another placed replaced the pedal( guess that's the one your talking about), another said FIPL sensor, and torque converter.
I have gotten enough info to believe that the Torque converter is out of the question, so then lastly electronic control from engine codes! Where would the FIPL sensor be? Maybe I can at least look for it?
The transmission downshifts on acceleration either during a gradual climb, especially when merging on the highway. It runs great otherwise. Its just annoying if its a long hill, because it will do it until it reaches the top... What is funny about your comment, is the Trans shop that worked on it, is the one that told me it was probably the FIPL?..
I was told to take care of ALL codes first, which is only my EBPV sensor and high press...thats it??!!
I was wondering if there is another transmission that is VERY similiar to the 4r100?? that they put on the Powerstrokes?... This downshifting problem started when the trans was rebuilt.. Thats why I thought it was a Torque converter... but the transmission fella's that told me to clear ALL codes first, told me that TRans shops will do anything to make the buck and that he thinks that's why put the "Tugger" shift kit, they probably messed up either drilling or wrong spring,that with a good Electronic tuner they could have made the trans work great, but they then wouldn't make more money off me!
The Banks Trans Command is suppose to help reduce the downshifting by increasing the fluid pressure thus holding the higher gear longer before a downshift is required. I'm not a techie so I hope I got this explanation right. ~ Bugjr ~
