check engine light and blinking overdrive light
Hi
I have a 1997 f350 crew cab 4x4 deisel. The check engine light keeps coming on and also noticed last time the overdrive light blinking. The truck will looose power and shift hard, then the lights turn off after driving awhile or turning the truck off and restarting. went to autozone and no code found using a acton autoscanner plus reader.
Any help would be great
Rest assured there are fault codes stored in your pcm. theres only a few scanners that can read the codes on your truck, and the one you mentioned isnt one of them. snap on makes one that will work, also the aeroforce scangauge does it too. theres a computer program called autoenginuity thats the one I use. theres a few others that I dont remember the names of. if all else fails and you dont want to cough up the money for one of the sacanners Ive mentioned the dealership can retreve your trouble codes for a price.
The edge is known to fry pcm's on these trucks, so I wouldn't recommend them. If you want a programmer that will read codes, superchips is probably your best option. Remember if you go this way, the programmers will not give you as much power as a custom chip will, and cost about the same. The benefit is the code reading.
I bought the total ford bundle. my wife works for ford in dearborn. we only drive fords, so it was a no brainer. Ive bought other stuff for my truck from clay over at riffraff and always get good service so I got AE from him too.
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
