5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
5.0 with 37's
Old 10-13-2012, 06:13 PM
redrum's Avatar
redrum
redrum is offline
5.0 with 37's
Anyone running 37's with the new 5.0? I plan on regearing the rear end but I'm curious how it would do towing up to 8000 pounds.
Old 01-03-2014, 01:42 AM
640 CI Aluminum FORD's Avatar
640 CI Aluminum FORD is offline
8,000lbs is fairly hefty load for any 1/2 ton truck, much less one that has to turn substantially larger tires than normal.
The 5.0L is a strong engine, I don't tow often with my FX4 5.0L, but I did recently tow 7,000lbs threw the mountains in new mexico and it handled the load very well, even at 8,000 feet above sea level it didn't feel overworked. For the record, my truck isn't lifted nor does it have larger tires on it.
So your engine has mustard to butter the sandwich no doubt. But I don't think it would it hurt anything to swap out your rear end if you are planning on towing 4 ton's with a lifted truck. 4.10's would do you good. 4.30's even better.
I say all this under the assumption that gas mileage is the least of your concerns.
Old 01-09-2014, 11:05 AM
cartmanea's Avatar
cartmanea
cartmanea is offline
I'd go 4.30s with 35s and 4.56s if you want to run 37s. It takes a lot of lift to run 37s on an F150 though, I would strongly advise against it if you tow.
Old 01-14-2014, 06:48 PM
Raul B's Avatar
Raul B
Raul B is offline
what size lift are you thinking of doing?
Wizness
6.7L Power Stroke Diesel
15
10-10-2015 09:45 PM
excaliber551
5.0L Coyote
09-05-2011 09:06 PM
leforrest
1997 - 2003 F150
02-20-2011 01:49 PM
kwiknova
1999 to 2016 Super Duty
26
05-07-2005 12:41 PM
tunruh
11-24-2003 06:08 PM
Quick Reply: 5.0 with 37's
