Navigator seats into 92 F250
Yes they are Black leather full power, not sure if they have the seat warmers, but I don't think so. The seats are out of an 2002.
Yeah it is going to be a pretty easy swap. the big thing i learned tonight is to make sure there is no forward or rear lean in the seat.
What I have decided to do is I cut the rivets that hold the seat mounts to the seat brackets on the original seats, that way I can reuse the original mounts. I am using a piece of 2" X 2" X1/8" angle, 18" long. This will bolt across the original mounts on the front and the new seats will bolt to the angle iron. I have not decided if I am going to use more angle or flat stock to extend the original mounting brackets rearward to bolt the new seat to or just drill through the floor and run a bolt through that way. If I go through the floor I will reinforce the floor with some flat stock
19-F250-78
10-10-2012 10:38 AM
Sycostang67
05-21-2003 04:39 PM
