urgent teanny questions!
Ok for an 85 6.9 with a c6, the most important question is. Does anybody have a clue as to why it won't shift into reverse? And why will it not properly shift gears? If you put it in drive it will not shift out off first unless I manually do so. It also will not shift back to first art a stop unless you romp on it. It does have enough fluid, and it will aid in to reverse after it sits a while. Please help!
It's on the tranny, passenger side towards the rear. It's a small vacuum pod with a single vacuum line going to it. Make sure it's hooked up and has vacuum. Rock Auto shows them for under $10.
IIRC, the C6 has 2 bands, one is for 1st and reverse the other for 2ond and reverse. I think they are both adjustable externally, but I could be mistaken and confusing it with the C4. Even if they are not both adjustable externally, the 1st and reverse one is. I don't recall the procedure off the top of my head, but you should be able to find out pretty easily with a search. There's a repair manual for the C6 in the parts stores that's pretty decent.
Ok update, after a fluid change (did drain out torque converter) and changed the filter, it now goes in reverse after a trip around the block. After checking my Haynes manual I verified that I am using the correct type of fluid. Got it up to the correct level let it sit a while. I drove liked a half mile in reverse around and around my large yard and foot three tranny warned up, drive it a couple miles, got home and it went right into reverse.
Idk out never had s problem going in first it was just reverse. I never actually drained out the torque converter if there was a different kind of fluid in it before I just drained out what was in the pan and put new fluid in and mixing it with what was in the torque converter and as sensitive as they are I guess it makes sense that missed fluid could of bed the issue with reverse. Idk reverse works now and that's the important part.
custom1106
01-07-2019 11:45 PM
91f250truck4.9l
08-30-2017 05:13 AM
inhonorofchuckgehner
10-06-2009 04:56 PM
hamcginn
1999 to 2016 Super Duty
09-13-2001 02:15 PM
