'51 F2 4 spd trans
My 48 is also mostly all original, except when I went to 16.5 wheels brakes and tires off a 75 F-250 doner truck, the tires are obviously much smaller than the original 17 x 750's. I went with the 4:11 ring and pinion set from Chucks Trucks which brought the engine rpm to mph ratio back to what it would have been with the original taller tires. Made the truck much more fun to drive.
rear change
If you are going to the trouble of the D60 swap, I would look for 3.73 gears.....4.11's would help though. There are several online tire size/ratio/RPM/speed calculators to help you.
Also remember, these trucks were not designed (in stock form) to go 70 mph on the freeway. The steering, brakes, etc just aren't up to it.
Changing from 4.86 to 4.11 ratios will drop your engine r.p.m. 15%.
If you have a 32 inch tire rolling diameter, with a 4.86 ratio, at 2550 r.p.m. you will be driving 50 m.p.h.
If you have a 32 inch tire rolling diameter, with a 4.11 ratio, at 2550 r.p.m. you will be driving 59 m.p.h.
I think you need to keep the 2 piece drive shaft. Too long of a drive shaft will "whip" and cause vibration problems.
Keep in mind that the engine has to make enough HP at a given speed to push thru the air, and climb any reasonable hills. Based on 38's numbers, the 4.11 looks reasonable. If you over-gear, you'll be into the gas pedal enough to trigger the power valve to open and gas mileage will plummet.
Ditto on the 2-pc driveshaft; one long shaft will have a lower critical speed where it resonates and that will tear up U-joints and bearings very quickly.
flynstone
15
06-11-2013 08:30 PM
robbie mcrib
32
04-12-2013 09:58 PM
tankmg
06-05-2012 10:50 PM
