leaking alum. rims
Old 05-03-2013, 07:42 PM
irydhd's Avatar
irydhd
irydhd is offline
Cool leaking alum. rims
2001 F150 CC. rims losing air ,slow but steady. All rims. Had the edges ground for rust and still leaking. anyone have any suggestions on how to stop the leaks. Thanks
Old 05-03-2013, 08:48 PM
JWC 3's Avatar
JWC 3
JWC 3 is online now
I worked at a tire ,alignment shop in the 90's . We use to fix that problem often . Clean the bead seating area , apply a sealer compound . It was basically a tire glue compound . We had it in cans , used it a lot . Alum. and rusted steel rims . I would sudgest you find a good tire shop that has an older crew that knows tires . Don't know where you are , but a Farmers Co Op or an independent tire shop might be your best bet . My local Co Op does my tractor tires , and they know how to seal a rim . I do my auto tires , and I seal them if needed . Good Luck !
Old 05-05-2013, 06:39 PM
irydhd's Avatar
irydhd
irydhd is offline
rims
Thanks , I am up in Wisc. and i think the salt and junk on the roads all winter have some effect on the rims.Will find another shop to do some work on them ,thanks again.
Old 05-05-2013, 07:51 PM
shapleigh's Avatar
shapleigh
shapleigh is offline
Tell them you need a bead buff and sealer, if they say "huh?", say never mind and go to the next. Also I would recomend spraying some soapy water aound the beads and valve stem to determine where it is leaking, it will bubble at leaks.........mark locations and show to shop.
Old 05-09-2013, 07:27 PM
irydhd's Avatar
irydhd
irydhd is offline
Thanks for the info on bead sealer .Will have to look into it.
Thanks again
Old 05-11-2013, 11:28 PM
BFTUFF's Avatar
BFTUFF
BFTUFF is offline
You need some black bead sealer. I've used it for years as a mechanic. I live in northern MN where road salt corrodes steel and aluminum wheels causing multiple leaks. Have all the rim beads buffed clean, install the tire, then apply black bead sealer to the entire wheel bead and inflate sealing the tire to the wheel, then balance. This will stop future corrosion and provide a long term flexible seal between the rim and tire. We run two sets of wheels/tires on all our vehicles: winter/summer. The set sitting months to be exchanged per season doesn't loose any air pressure. Don't use "Ru-Glyde", that's for tire installation only (soap). Insist on black bead sealer.
Old 05-12-2013, 07:14 PM
irydhd's Avatar
irydhd
irydhd is offline
Thanks for info on black bead sealer. Salt sure does eat them up.
Old 05-12-2013, 07:57 PM
JWC 3's Avatar
JWC 3
JWC 3 is online now
Did the sealer fix your leaks ? I would think it may .
Old 05-15-2013, 08:11 PM
irydhd's Avatar
irydhd
irydhd is offline
Yes leaks are fixed. Thanks to all for the help
troverman
2017+ Super Duty
22
01-18-2024 08:11 AM
BeerHunter125
1997 - 2003 F150
08-21-2015 09:41 PM
AbandonedBronco
1978 - 1996 Big Bronco
10-19-2009 10:21 AM
Paul K
17
06-27-2007 11:44 AM
preppypyro
British Columbia
04-23-2007 12:50 AM
Quick Reply: leaking alum. rims
