Cab/Frame Mount bolts
Old 05-03-2013, 06:55 PM
MGarner's Avatar
MGarner
MGarner is offline
I am installing new cab mount bushings in my 66 F100 and would like to know how much torque to put on the bolts.
Thanks
Old 05-04-2013, 09:56 AM
Faber's Avatar
Faber
Faber is offline
No idea, hopefully someone more knowledgeable will answer.
I had my wife with a wrench in cab and socket on bottom, snugged up good. It had a sleeve to avoid crushing the pan, but I don't know that was really necessary.
Then I either did or definitely meant to tack the nut to the bolt for a lock washer.... Avoiding inhaling fumes from plated steel.
Old 05-04-2013, 11:12 AM
MGarner's Avatar
MGarner
MGarner is offline
Cab/Frame mount bolts
Thanks for the reply. Called a friend who is a machinist. With the type and size bolts I am using he gave me the correct amount of torque. He said two grunts should be enough.
Old 05-04-2013, 04:54 PM
Faber's Avatar
Faber
Faber is offline
Lol, awesome : )
Old 05-04-2013, 05:43 PM
Kurtboyd's Avatar
Kurtboyd
Kurtboyd is offline
Old 05-04-2013, 08:16 PM
schoo's Avatar
schoo
schoo is offline
Used two and a half grunts and the mounts just started to bulge
Roy
Gigemags05
1947 and Older Ford Trucks
09-13-2017 11:42 AM
BlueFord65
06-28-2016 08:33 PM
GMbusa
18
03-04-2016 12:43 PM
JWest
16
07-13-2007 08:58 PM
79 posi
04-04-2005 08:01 PM
Quick Reply: Cab/Frame Mount bolts
