PCV valve ?
Old 05-02-2013, 11:51 AM
haven56's Avatar
haven56
haven56 is offline
PCV valve ?
My 56 has a 1963 292 motor in it. I don't see a pcv valve anywhere on it. Also the block does NOT have the ventilation tube on the drivers side down by the fuel pump. Does it just vent through the oil filler cap?
Old 05-02-2013, 12:30 PM
Jag Red 54's Avatar
Jag Red 54
Jag Red 54 is offline
Both of my Y-blocks are 1955. They both have breathers on the driver side of the block and the oil tube. Some PO may have blocked off your block breather. They tend to drip oil occasionally and they may have wanted to eliminate the bother. If I were you, I would restore the breather for better block ventilation. Good luck, Jag
Old 05-02-2013, 04:29 PM
haven56's Avatar
haven56
haven56 is offline
my block has a flat area on it with 2 threaded holes but it looks like nothing has ever been attached there.
Old 05-02-2013, 04:36 PM
Jag Red 54's Avatar
Jag Red 54
It might be that there was no breather, but it had a PCV instead and a PO has modified that. I do not know what the 63 Y-blocks were configured like. Maybe if you ask in the Y-Block engine portion of this site an expert would have the real info. Good luck, Jag
Old 05-02-2013, 05:42 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Did someone put on aftermarket valve covers, that might have eliminated the PCV connection? Somewhere right around '63 is when PCV's were mandated.
Old 05-02-2013, 08:13 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
PCV introduced in 1961, was mandatory in sold new in CA vehicles, possibly other states, but some states didn't require PCV until the mid 1960's.
1964 292 same as 1961/63. 6A666 is the smog valve.
Old 05-02-2013, 09:15 PM
haven56's Avatar
haven56
haven56 is offline
My truck was built in KC and been in Kansas it's whole life. I'll check mine t against the diagram.
Old 05-03-2013, 11:54 AM
haven56's Avatar
haven56
haven56 is offline
I haven't been able to check yet but mine seems to be the intake manifold type. Thanks for the illustration. What is #6A665?
Old 05-03-2013, 04:20 PM
NumberDummy
C1AE-6A665-G .. Adapter Assy-Crankcase Ventilation.
CShroom
25
05-26-2010 12:32 AM
spurredon
07-26-2007 10:54 AM
ibuzzard
03-17-2004 07:43 AM
f1drivr
01-17-2004 07:01 PM
atticmole
13
09-17-2003 10:28 PM
Quick Reply: PCV valve ?
