Need Parts Help
Need Parts Help
Looking into tearing into the oil cooler this weekend to repair some coolant leaks in the area. Does anyone have a parts list which would included all the gaskets needed for this job. I am guessing I would need turbo exhaust gaskets, EGR cooler gaskets, intake manifold gaskets, and various other gaskets to the oil cooler coolant ports.
Thanks for any help.
Here's some help:
Ford OEM Intake Gaskets (need 2) 3C3Z-9439-AA
Ford OEM EGR Gasket Kit w/o intake gaskets 3C3Z-9433-BJ
The EGR kit has the paper turbo gasket. If you order the Oil Cooler kit it comes with the O-rings I believe (mine hasn't come in yet so I'm assuming), otherwise you need those o-rings.
oil cooler kit: Oil Cooler Latest Ford (comes w/ new style SS screen) 3C3Z6A642CA
optional to clean the EGR: EGR Gasket Set 3C3Z-9P455-AB
That should get you started...
