2 a/c questions
2 a/c questions
I asked in the hvac section with no luck,.the po of my truck said a/c compressed is froze up.how do I tell this?my last 95 150 didn't "click on/off"but blew out cold.and I belive its r 12 Freon.can I put in the 134,or where do I buy r12,or can I converert and how?thanks for input
first most of the old compressors dont click, at least my do not but the motor will bog down a little. no mixing r134a and r12 is not a good idea, r12 is spendy but you can get a drop in replacement. just google r12 direct drop in replacement, r134a leaks super easy as its particles are 1/1000 the size of r12 particles so thats food for thought on the conversion. also get some cheap r 12 manifold gauges and see if its low or have it done by a mechanic. if the compressor is froze or wont engage it could just be low, if its low have the mechanic put dye in it to see where its leaking, if its not low than the compressor is bad and will require a new compressor. they are around 150 dollars
Received 3,108 Likes
on
on
on
My honest opinion here is that unless you have experience working with A/C systems professionally and have ALL of the equipment to evacuate it properly, take it to a pro and have them fix it.
At the minimum have them evacuate the system for you before you begin working on it.
If that is the route you choose, after it has been evacuated, read through this.
1993 Ford Bronco A/C Conversion to R-134a pictures, videos, and sounds | SuperMotors.net
on
I took an online test years ago to get my EPA 609 cert. Total cost was $10 USD at that time. Unless I purchase from distributor or local dealer no one has ever asked for a copy of my EPA 609.
On my last few projects where I needed R-12 I scored small cans on E-bay for less than $20 each. The E-bay listing stated I needed an EPA 609, but they never asked for a copy. As long as there is E-bay and other sites I see no reason to go through the hassle of converting to R-134a (I am not a fan) or sourcing drop-in replacements for R-12.
on
Social_Joe
01-30-2014 02:47 PM
diego-ted
19
08-31-2004 07:41 PM
smandzak
05-26-2004 04:13 PM
