466 swap in Bronco and an issue
04-28-2013, 07:58 PM
on
I just swapped in my 466 in my Bronco. It has a c6/np203, 3.50 gears, 33s except one that is a 31 on the rear passenger side (will replace with a 33 soon).
Here is the engine running.
Now I am having an issue when driving. My RPMs are too high for the mph I am going.
Here is an example. Keep in mind I think I am 5 mph off so the speedometer isn't correct (measured with GPS).
Here is a video of me driving...notice the RPMs and speed.
Any ideas why it is reving to high for my speed? It should be around 2,000 RPMs.
04-28-2013, 08:01 PM
Links to videos plz, they no work for me.
N dam disappearing posts today.
04-28-2013, 08:04 PM
04-28-2013, 08:23 PM
on
I had to edit and send it to Youtube.
04-28-2013, 08:26 PM
Idk, rpm range looks ok to me for a C6 and 3.55s
04-28-2013, 08:31 PM
on
3.50s
Kris calculated that I should be around 2,000 RPM at 55 MPH with 3.50 gears with a C6 1.1 3RD gear ratio.
04-28-2013, 08:32 PM
Its a touch high by the calculations but really OK. It was much higher last night for some reason
04-28-2013, 08:34 PM
04-28-2013, 08:35 PM
on
So it all looks good now?
I don't know what kind of converter I have. I forgot.
04-28-2013, 08:37 PM
Converter shouldn't effect cruise rpm
04-28-2013, 08:38 PM
If it has a higher stall than stock, that will raise the cruise rpm too. It will never reach 100% lockup on that style n
04-28-2013, 08:48 PM
on
Guy that built my 460 said it is a stock converter 800-1000 rpm
04-29-2013, 07:00 AM
The 88pickup i had on 32's with a 351 and a 3spd ran around 24-2500 Rpm in the 55-60 range
ManfredVonRichtofen
Offroad & 4x4
32
04-30-2013 08:45 PM
ChrisAllen1090
1978 - 1996 Big Bronco
09-22-2002 08:31 PM
Jrock909
Bronco II
06-29-2002 07:40 PM
dassmoof
06-07-2002 01:27 PM
