can someone bench dino this set up
dyno not dino.
1965 352 block, H395P standard 360 pistons (four relief valves), 390 crank and 390 rods, Crane Cams 343942 272/284, Lift .533/.563, stock lifters, heads are C6AE-U ported polished with 2.09, 1.65 valves, edelbrock intake performer RPM, edelbrock 1405 600cfm carb, shim head gaskets 0.20, long tube headers running through glass packs
dyno not dino.
I borrowed this data from the internet, no lab name was given.
Muffler Flow Testing
All tests via an independent lab
All tests @ 15” wc
2 “ Straight Pipe 283 CFM
2 ¼ “ Straight Pipe 365 CFM
2 ½ “ Straight Pipe 521 CFM
2 ¼” Typical Bent tailpipe 268 CFM
2 ½” Typical Bent Tailpipe 417 CFM
2 ¼” Inlet/Outlet_ Glass Pack Tips- No Louvers- Smooth 274 CFM
2 ¼” Inlet/Outlet- Glass Pack Tips-Louvered 133 CFM
Same as above set for reverse flow 141 CFM
2 ¼” Cherry Bomb 239 CFM
2 ½” Cherry Bomb 294 CFM
2 ½” Inlet/Outlet Dynomax Super Turbo 278 CFM
2 ½” Inlet/Outlet Ultraflow Bullet 512 CFM
2 ½” Inlet/Outlet Gibson Superflow 267 CFM
2 ½” Inlet/Outlet Flowmaster ( 2 Chamber) 249 CFM
2 ½” Inlet Outlet Flowmaster ( 3 Chamber) 229 CFM
2 ¼” Inlet/Outlet Thrush CVX 260 CFM
2 ½” Inlet/Outlet Maremount Cherry Bomb 298 CFM
2 ½” Inlet/Outlet Hooker Aero Chamber 324 CFM
2 ½” Inlet/Outlet Hooker Max Flow 521 CFM
2 ½” Inlet/Outlet Borla Turbo 373 CFM
2 1/2" Inlet/Outlet Magnaflow 284 CFM
Part 2
And according to a dyno post i saw but can't remeber what motor. The motor had a loss of 10HP and 11ft/lbs of torque between louvered and non.
So as you can see depending on what "glasspack" you are going to run or are running they can hurt flow a fair amount, even more if you are running smaller pipe than optimal for the engine.
As for the edel 600 carb. I don't see where you would have issue with a 600cfm flow carb until you got into the 5000+ rpm range. I beleive too many people over size a carb and sacrafice response to say "i got a 750 double pumper on my 302". Now as for it being an edelbrock, The one i have is VERY reliable and never gives me any problems, but the difference between that and my 650 mighty demon is very noticable by the seat of pants.
Look around on the net and you can find carb CFM calculators, just be honest with the RPM range you will be running it in when you pick it.
All tests @ 15” wc
Part 2
Edelbrocks tend to be undersized compared to a Holley of the same CFM rating. A 600 will limit the topend performance on a 390. A better pick would be a 750 cfm carb. And as shown in the post above, glass packs are notorious for restriction. Especially the smaller I.D. ones. The smaller the I.D and the longer they are, the more restriction you'll see.
jj22ee
11-08-2005 01:43 PM
skater2570270
13
10-21-2004 10:12 PM
1962_Fords_rule
16
07-31-2004 04:43 PM
redneck hillbilly
07-08-2003 08:14 PM
